subscribed.. this looks interesting keep trying.
custom top hats
Originally posted by AstroVannin View PostWeir is making a set for my OMNI's too.
I went with a 2.5" extention though.
1993 CB6 Coupe Seattle Silver YR-94M
Originally posted by Acclude4gens are win. It's in the bible somewhere.
Members Ride Thread
1993 Accord Coupe- Summer ride
http://www.cb7tuner.com/vbb/showthread.php?t=130064
1995 Civic Coupe - Winter/DD
http://www.cb7tuner.com/vbb/showthre...53#post2744953
WEIR top hats...
Members Ride Thread - http://www.cb7tuner.com/vbb/showthread.php?t=121452
Originally posted by slammed4thgendustin, you are a dick!
officially the lowest ive seen now
Threading to the frame?
Im assuming you mean where I cut it out. Yeah its an ugly job .. I only had a cut off wheel on the grinder at the time. Im having a set of 1/8th plate rings made weld to the stock strut tower to reinforce it. I was thinking it looked a little thin after I did the cutting too.
Im not concerned about the saftey of it. It would take a long time before that ripped through the strut tower, but Il put the plate on just the same ... Better to have and not need, rather then need and not have.
ok so i was thinking about the top hats. if you have extended top hats you will have full shock travel even tho you car is low. so it wont bottom down. now if you have normal spring travel then the car will scrape more. right? when the car bounces it will just go all the way down,??Turbo F22 Under Construction
they look good on the car...just as long the hood can fit or close properlyVS
Mercyboy: I rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
MERCYBOY THREAD:http://www.cb7tuner.com/vbb/showthread.php?t=158241
1990 RHD Honda accord si CB3 Canada http://www.cb7tuner.com/vbb/showthread.php?t=196287
MY CB7 ON YOUTUBE: http://www.youtube.com/watch?v=CJID_IxwiNY
