For some reason my Windows on my passenger side have trouble going down and up....what is it that I can do to stop this from happening? What do I use to grease the tracks? Also the back window will not go up all the way, about a 1/4 of an inch. It is at the end of the track....how can I adjust it to go all the way up?
window has trouble going down
motor may need to be replaced?
you can lube window tracks with silicone spray,roll window down,spray exposed tracks at top half of door,then use straw from can and spray between window and track for about 15 seconds so silicone spray will run down between window and track.run window up and down several times
check and see if your back window is off track or not because my mustangs back windows are off track and dont go up all the way also when i bought my cb7 i had the same window trouble you have been having they were going up slow and sometiimes not working at all so i replaced the fuses and regulators and it worked fine
X2... I had trouble putting my drivers window down because the felt that backs to the window on the inner chrome strip had worn down in addition to tinted windows made it even worse. After replacing my inner strip (its held in place my metal tabs which bend easily making replacement a breeze) my drivers window now works great.Originally posted by Accrdwgnguy View PostMy windows have trouble going down because they get stuck on the rub strip mounted on the door panel. Have you also run into this issue?
The same thing happens to my passenger side window after it rains but I honestly think it's my regulator lolOriginally posted by Accrdwgnguy View PostMy windows have trouble going down because they get stuck on the rub strip mounted on the door panel. Have you also run into this issue?
alot of times on accord, the rubber insert in the tracks will start to walk downwards, as they slide downwards they bunch up, causing my drag on the window, roll the window all the way and then try to slide the rubber up again. after that lube them with a silicone spray. i did this to my buddy's 4 door and they work great now. hopefully this will fix your issues
