removing front blinkers
    OK, I feel like an idiot. I'm trying to remove the front lower turn signals, so I can get the bumper off. I read that you're supposed to undo the Phillips screw on the inboard side of the light. I can see the hole that looks like it should have a screw in it, but can't see the screw. Is it just recessed really deep?
    I thought that maybe someone already took the screws out, but if that was the case, wouldn't the light just slide right out?
    It's recessed inside that plastic sleeve. Get a long Phillips and you'll be good to go.
      That would explain it. I think that my screwdriver is too fat to fit inside that hole.
        "Blinkers"
        Been a while since I've heard that one.
        MR Thread
        GhostAccord 2.4L Blog
        by Chappy, on Flickr
          They arn't THAT recessed. You should be able to see them, use a flash light and check. If they arn't there, just pull out the side where the screw is (supposed to be) first, and then pull it straight out. Theres a tab that keeps it in place on the outer part of it.
          '93 LX Wagon (On the back burner)
          '92 EX Wagon (Traded)
          '93 EX Wagon (Current DD)
            Giggity!
