Alternator Whine
    Alternator Whine
    hi
    ive got a pioneer hu (deh-p7500mp) and when i plug my amp to the h-u ive got a bizarre noise (they call that alternator whine on google)
    i change my ground of my h-u
    change the rca
    change ground of amp
    the sounds still there ...
    ah and ive try with a noise remover and the noise is still there .....
    plz help me out with this one !
    What kind of amp are you running? Are you sure your ground choices are solid bare metal? We really need more info to help you out.
      i run an 600 w amp
      my ground are on bare metal
      ... what do you want to know ? tell me and ill tell you
      the sound is more present when i accelerate
        Well, what brand of amp would help. Are you sure your wiring is correct? If you've got a cheap amp or one of your channels is out of phase or if the HU ground is bad, you could get whine. The more information you volunteer and the less we have to drag out of you the better. lol help us help you.
          wen you wired your amp, did you run the rca's and the power wires all together? this is the main cuase of alt wine. there is plenty of space to run the power cables and rcas seperate under the plastic peice that is the door sill. it just pops up. run your wires thru there. if you have to cross wires, cross at 90 degrees.(criss-cross).
          you'll love my nuts!
            yea what he said, though i ran them on the same side all the time and get no issues.
            you can be looking at either a bad head unit, or a bad amp. also what is the condition of your battery...those act as a big filter in engine noise.
            Retro!
            Hater
              borrow a friends radio and hook it up in ur car and see if the noise goes away, or try grounding the RCA wires
              F/S:Pioneer Premier Deh-880prs w/ ipod adapter $220
                I have a similar situation. I have a DLO Zune car audio receiver. When I'm not playing music I can hear the alternator whine through the speakers.
                  i have try an other radio and it's all okay !
                  so i got a bad headunit ?
                    my uncle has a stock passport headunit on his passport and it does that like crazy everytime you accelerate.
                    lol its like a little supercharger sound haha.
                    Yes my name is Dang, Don't use in vain
                    1992 Honda Accord EX (Coupe/Bordeaux/Auto)
                    1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
                    2008 Honda Accord EXL (Coupe/SanMarino/6spd)
                      tell your uncle to amp that up, and put some speaks on the outside of his passport!! no one will ever mess with him!!
                        Yep that's your problem then... I've seen recently that Pioneers are prone to give this whine... My boy has gone through 3 HUs (all pioneer) and they all have done this
                        and he finally tried another brand and poof.... sound was gone
                        Myspace.com/bobster3825
                          its a bad RCA ground in the HU. simple fix is take about 7-8 inches of wire and ground it. then strip it back far enough to let the rca slide over it... very simple and works.... there are places on the back of the radio u can use for a chaisis ground.
                          Members Ride sold...
                            I get this when my power or ground wires are too close to the speaker/signal wires.
                            Poor shielding, most likely.
                              i had pioneer all my life and it was fine. just the pick of the litter i guess.
                              Retro!
                              Hater
