box material. need to build a new one
    so my uncle and i made a box when i first got my subs. when to home depot to get wood and got the cheapest shit they had because i was broke yet anxious...i believe it was particle board but don't quote me on that. so we put the box together with wood glue and a nail gun and then put the face on with screws in case i ever wanted to change it because i have square subs. so now the box broke on the opposite corners of the face. i think its the material i used. i think i need to use mdf next time or is there something better? and btw the box is sealed.
    also i used "table cloth vinyl" to wrap it because it was the only black stuff they had. got it from handcock fabrics and it was on sale. problem is is that the stuff had like a 1/4" padding on it and that made the folds and sealing it a pain. i think next time i just want to spray it with something that will protect the wood and call it a day. i don't care about how it looks and i suck at wrapping anyways lol.
    If you don't mind spending a little bit of money, I think it's about 30 or so a sheet, see if you can find the 3/4 mdf they use for counters, it has the white laminate shit on it. Put the white stuff on the inside, and I'd recommend screwing the box together with 1 5/8 inch wood screws, then some caulking on all the seams and joints inside the box.
      IMO, MORNING wood is the best for box building...
        OP - definitely spend the money for at least 3/4 MDF. with or without the laminate on it. And make sure you build the box correctly, subs need a specific amount of air. Yours should say how much in the manual. You can also find calculators online that will tell you the specs for any kind of box you want to build to match your subs, from a simple sealed enclosure all the way up to a seventh order bandpass.
          http://www.rockfordfosgate.com/rftech/rftech.asp
          That link should help you. Tells how to calculate box volume, how to wire up woofers... etc
            ....... [crickets crickets ]
            Well.. 3/4 mdf, glue and screws... If you use something to seal it make sure its safe for rubber so it wont mess up your suround while it dries.
              3/4" Mdf
              They rise their wooden pints and they yoik and sing
              And they fight and dance 'till the morning
              Dont forget my MRT for my 1992 Honda Accord LX
              Everything in Japan is made with carbon fiber and used panties.
                Fiberglass.....3/4 mdf......plexiglass.....it doesn't really matter as long as it can support the sub and contain the airspace it needs.
                YouTube Clicky!!
                  lol morning wood is always good for a box. But ya 3/4" mdf is what i always thought. I never knew about the white laminate on the inside though...is it better than just standard non-laminated mdf.
                  1992 Honda Accord Coupe LX
                    i find morning wood is a bit stressed, I prefer to bury my drivers in box comprised of pussywillow.
                    ive bought used counter top laminate from recyclers. lots cheaper than mdf, and the laminate plastic compinsates for the weakness of the particle board
                    you'll love my nuts!
                      lulz
                      Underground.Society
                      Originally posted by Deevergote
                      If it doesn't really matter... shut the fuck up and let it be.
                        ^^^^the only way to go. on the sealing part as long as you wait the appropriate drying time on the silicone you will not have to concern yourself with the rubber surround part. also regular wood glue is not meant to fill big gaps, so as long as you gaps are tight then you will be fine, and let the glue dry for at least 24 hours prior to applying any silicone or sealing agent to it. good luck on you project and let us know how it turns out.
                          get some medium density fiber (mdf) and some insulation, gorilla glue, and some wood screws. i counter sync the holes so u cant see the screws and fill them in with some wood putty then router the edges and it looks pretty sharp. oh ya and you might wanna drill holes in the mdf prior to screwing it together as it may split and crack the wood.
                          One mans turd is anothers golden nugget
                            i went wit 3/4 MDF and i thought i had great sound and quality... and it was pretty easy to work with.. i didn't build the box my boy did but it looked pretty easy and cleaner than would! but hey to each his own.
                            " The value of life can be measured by how many times your soul has been deeply stirred " - Soichiro Honda
                              Is said you can use MDF or HDF. Depending on the application. For instance it sounds like you may have 10 or 12" solo squares or the new MTX squares. That case you could use the 3/4" MDF or you could use 3/4 HDF (takes more patience to work with) I had a buddy who had an 18" Kicker Solo X and the box had to be made from 5/8" HDF and the face had to be 1" to support the sub.
                              As far as sealing goes, use CLEAR silicone either i a squeeze tube or in a caulking gun tube. Allow it to dry for at least 2 hrs before mounting the sub and your good to go.
                              "you can catch me swoopin 4G coupin switchin lanes" haha haha.
                              1993 SE coupe drag car ahoy!
                              1992 EX coupe 5 spd **sold **
                              Did work for: jhoff_cb7
