Tiny System!
    Tiny System!
    So I got this 8" inch, 400w Pioneer with the box for 20$.
    With what used amp can I combine it with to get some good sound??
    Also what used deck should I get?
    best bet save and buy something else
    BUILT NOT BOUGHTOG OWNER,SINCE 06/1992
      x2 you wont get much thump from an 8" maybe a 10" but like he said save your money and get something better, you will most likely come onto a good deal for bigger subs....
      ^^MY OLD RIDE
      http://www.cb7tuner.com/vbb/showthre...91#post3052591 <<**CURRENT DA9 BUILD**
        I say use what you have, just buy a good amp so when, not if, you get ready to upgrade, you won't have to shell out more money for a new one.
        YouTube Clicky!!
          X2, or if you can find one dirt cheap just to get you by for the moment.
            I dont wan't/need a big system just something that will get me a little bass because I park my car on the streets and they already broke into my car so I DON'T want anything expensive. thanks for your advice!
              It would really depend on the specs of that particular sub. Im pretty sure Pioneer makes a decent 200-300w mono amp that would probably push that 8" just fine. Check the power handling and ohm load of the sub and go from there.
              MECP Certified Installation Supervisor
              Bought from: TypeG,mak,CB7_ACCORD,ChampCoupe,Blackex
              Traded with: Cb7xChun
              Sold to: Rob_is_legend,DaddyO,daheavyking
              Sedan MR Thread Coupe MR Thread Prelude Si MR Thread
              My huge For Sale Thread
                i say keep the 8" sub
                i would buy a 4 channel amp and bridge 2 channels and run it to the 8
                then if you get tired of it and want to upgrade then you can use that amp for midrange/high speakers
                i always buy old school rockford, jl equipment myself
                  BUMP! So I got the amp for my 400w Pioneer IMPP. Its a Kenwood KAC-628 300w. Will it work??
                  KAC-628
                  2-Channel Power Amplifier
                  Key Features
                  • Maximum Output Power: 300 Watts x 1
                  Power Ratings
                  • Bridged Power Output at 14.4V (1kHz, 0.8% THD): 150 Watts x 1
                  • Power Output at 2 Ohms, at 14.4V (1kHz, 0.8% THD): 75 Watts x 2
                  • Power Output at 4 Ohms, at 14.4V (20Hz-20kHz, 0.08% THD): 50 Watts x 2
                    Should be perfect for that lil sub... Just set ur gain properly and youl be good to go..
                    My System
                    http://www.cb7tuner.com/vbb/showthread.php?t=165155
                      should give you a little extra bump but when your ready to upgrade this should be a nice step.
                      http://www.sonicelectronix.com/item_...nce+1250W.html
                      with this amp
                      http://www.sonicelectronix.com/item_...FA1-2000D.html
                      in custom to factory spec box should give you some nice bump. hell i just have a 12w3 in a box that is way to small with a crapp dual 460watt amp and my system is pretty clear and more then loud enough for me.
                        with this amp
                        ummm no.
                        Members Ride sold...
                          An 8" sub aint gonna sound to good with any 150w + amps. more like boom boom BANG!!!!
                            whats that supposed to mean???
                              MY BROTHER HAS 4 JL AUDIO W7 8....they bang out
