I've had my system rockin for a long time, but recently I was getting static at higher volumes. I decided to redo everything cleaner, I bought a new headunit (old one's drive jammed) redid the harness but used the honda ground wire (Worked before fine). So I re-ran the RCA on the left side, and power thru the right side of the car (They were on same sides.). Cleaned up my amp, and all other connections and ran a bigger ground (so it would match the power gauge wire.) Checked for broken cable, or anything making contact and polished all grounds. When I turn up the volume it seems my Subwoofers go into a seizure and distort, but if I turn the subwoofers OFF in the headunit all is fine. I checked the subs, they aren't damaged, wired properly, amp is wired properly I think my amp may be going out. Anyone got any good suggestions??
