I have been out of touch with the car audio game for some time, so bare with me. The setup im thinking of is relatively simple: A set of CTX65CS's up front, a single IDQ12V2 in a custom slot port box for bass, and run the whole thing with an mb quart DSC4125. Would this be considered a decent budget "sqish" setup? Also, would it be wise to upgrade my electrical system in any way? Any ideas on how to tune the sub for this application? Sorry for a million questions, but i do appreciate any suggestions.
Audio guru opinion's needed
well u dont tune the sub...u tune the box made for the sub....and depending on how low in ohms the amp can go u choose the dual 2 or 4.....um i guess itd be a good set up....i dont see a reason to upgrade electrical....ur not trying to go compete in those things r u....if ur using it for daily driving ull be fine....
for tuning the box ull either hit lows or highs.....lows sounds better but highs gets ur db number count up....go for lows...or tune the box to hit both....and um u prolly dont koe how to build a box i assume....so just go to ur local car audio place and ask about customizing a box for ur honda.. they are alot better for u than a damn probox or that other shit...and u can get the box specificly designd for ur subs.. 3 cubic feet is a good choice for them cars..... my bro got a 92 honda and he goes and competes with his stuff...and he works for car auido...so i kinda koe what im saying for a newbie lol.... i got a 91 that im working on....i murdered my out lol...but yea...this should help
Originally posted by richie92ex View PostTrue, ya, i can find the info for box specs and even build it, I wanna know what "Hz" to tune the box to so it works well in a cb sedan.
If you go ported, you typically want to start rolling off around 40-45hz... Or shoot for an f3 point of somthing like 35-40hz, this will give you clean solid bass all the way down to about 20-25hz, I wouldnt play a sub any lower, loud anyways due to possible unloading effects the box could have on the sub...
Originally posted by tgdrums1990 View PostI reccomend you do a google search for WinISD, and download it. Take the t/s paramters of your driver, and create your driver in the program, and design a box for your woofer....
Originally posted by richie92ex View PostGoing to check it out, thanks man!
ID recommends a 1.25-2.0 cu. ft box for that sub. What type of music do you listen to?
ive played with those subs before i got a good result from 1.7@34hz its very accurate sub, but when i built a similar enclosure with a lower tune it started breaking up and couldn't get the lows like i wanted after 2 boxes later i found a good median at 1.7@35hz.
F/S:Pioneer Premier Deh-880prs w/ ipod adapter $220
Originally posted by hybrid90accord View Postive played with those subs before i got a good result from 1.7@34hz its very accurate sub, but when i built a similar enclosure with a lower tune it started breaking up and couldn't get the lows like i wanted after 2 boxes later i found a good median at 1.7@35hz.
