alternator upgrade
    Im running an powerbasterds 220 amp its 110amps at 1500 rpms and 220+ amps at 2500rpms best bang for the buck 1 year replacement coverege theyre only 300$ and 50$ to have it powter coated any color.....just food for thought....
    My 90 coupe Mr thread....
    http://www.cb7tuner.com/vbb/showthread.php?t=178452
      Is that the universal self exciting one(one wire hook up)??I really wanna see pics I plan on buying one of those..
      Car audio classifieds...
      http://www.caraudioclassifieds.org/f...ferrerid=12120
      Youtube page http://www.youtube.com/user/blackoutt334?feature=mhee
        hey guys. i have 2 12'' rockford subs powered by a 1200 watt sony explode. 4 gauge wirring and 0 gauge grounds, 2 farrat capacitor. its been 11 months with this system and now im getting a flickering charging ligth. so ima get a better alt.
        question: wut u guys think about this one before i buy??
        http://cgi.ebay.com/ebaymotors/92-HO...Q5fAccessories
        thank you
          thank you
          Id say check your batt if it just started i had an setup like that in my old accord and the alt powered it fine....i had an red top optoma in that car and it never gave me any probs and i only had an 1 farid cap....
          Edit....if the batt light is coming on then you need an new alt...or in my case i needed an new belt lol. ...that alt is an refurb thats been upgraded they dont tend to last....it will do the job great for what you have.....but i wouldnt buy an upgraded referb without an warrenty...
            Yep the fizzal220 universal ill get some pics up in an weekish or so...
              i recently got an ever start battery from the junk and its been working sligthky better than the green top interstate i had ( turned out it was retaining charged so i replaced it )
              i dont know what to invest on first. a yellow top optima battery or a high out put alt?
              and its got a one year warranty
              OHH YEAH. dude, this flickering ligth has been on my ass for a year now. i havent done anything about it. im thinking stock alt. cant take the heat.
                the fact that its been going on for an year and your alt is still working says its prob an ecu or bad wireing....id check the volts at the alt to see though it should run 14 volts all day....if the alt is good id say start at the batt but if it needs an alt then fix it first....your voltege regulator is in your ecu if its going out id worry about that before anything else. ....get that light to stop flickering before anything else.... Or you could end up with an very worse problem down the road.....
                  Unless your alt is just crapping out period your stock alt should handle that 1200 watt amp no problem I know its not pushing anywhere near 1200 watts tho,I'd replace the cap and do like a batcap 800.
                    well this is probably a dumb question. when your alternator is bad, does the battery light automatically come on? and is there any way to prevent it from going bad because i have never changed my alt before, so it does worry me.
                      If it comes on solid yes your alt is out.... flickering i would guess is voltege regulator....ive changed an few out there not all that hard to do. ...i once had an probe that was an nightmare our cars are easy. Civics are an luttle more tricky but not bad.
                        thanx. it makes me feel better on with the subs
                          well, i also just replaced ecu with a working one ( my last ecu failed it went on limp mode ) and the flickering continues. you think maybe bad audio wirring? everything looks good and the sound has a lot of potential but maybe i should all wires are new and in good shape
                          anyway ima get a high output alternator for sure so anyone recommend a good alternator. i got like 150$ to spend on it.
                            At that point id say replace the alt check belts wireing going to batt and grounds or....i dont have an book on me to check but it could have an relay that went bad.....
                            As far as alts try shucks or auto zone......and they can tell if your alt is bad there just bring in your old one and have it tested....
                              ^^^^ after that point only thing left would be replacing your wire harness or the ecu u got is also bad ive had that happen before two...
                                so you still say that
                                http://cgi.ebay.com/ebaymotors/92-HO...mZ350412444653 is a no go? one year warranty
