I have a JL Audio 12' and today while I was playing it, it started to make a weird humming noise and it still hits beats when I play it pass volume 8 but anything below volume 8 I can hear the annoying noise? Any thoughts on it
My subwoofer makes a loud noise
probably a grounding issue. Are you using the factory head unit, or an aftermarket one? I've seen this happen with factory headunits using hi-level/low level converters for the rca outputs.
I had a similiar problem with an old MTX amp I had. It turned out to be a bad RCA input on the amp. You might wanna check your amp ground, headunit ground, maybe swap in a new set of RCA cables too. Make sure your RCA's are run away from your power wire, or any other high current wires.
If you have an Ohm meter, ohm out your sub to make sure it's within spec to rule that out.Last edited by wherm; 05-31-2011, 11:17 PM.
could be bad jacks to check them where they input on your amp give them a little thump and see if the thump travels to the actual speaker its self. next could be the ground in some cases if you ground on certain body parts it can pick up road noises and travel to the amp then to the sub. also could be the amp its self might have a short or something of that nature. next check the sub give it a little push while playing and see if the noise gets worse or goes away can be a voice coil starting to go bad if so then you can either get it fixed or just buy a new one. i have had many systems and the kit from walmart has giving me many problems with bad feed back in my system for one there jacks are crap beyond all means. some people may have luck with them but i never have that's for sure.. check the head unit also and make sure its not grounded out to the car at all it can casue noises to travel from car all the way back also. sit amp on bare metal it can casue problems also. do a through check of everything listed and if the problem consists you may either need a new system its self or take it to a local audio shop and have it checked they are profesionals for that stuff.. hope this helps some man later...
if u have good wire, it dont matter cause i have my power at less 3 inches away from my rca and i dont have that problem its more then likely the ground just clean the paint off and it should be fine unless its a cheap amp kitLast edited by duckers1074; 06-11-2011, 10:59 AM.
You can have walmart amp wiring kit on a budget (like me) and not have problems as long as is in contact with the chassis and not on top of paint it will stop the annoying whinning and loud feed back on your system!Originally posted by duckers1074 View Postif u have good wire, it dont matter cause i have my power at less 3 inches away from my rca and i dont have that problem its more then likely the ground just clean the paint off and it should be fine unless its a cheap amp kit
if your amp is mounted to something metal it will make that sound. i had mine mounted on my rear seat and it started to make that sound. i thought it was my ground wire but, no. i just took some 2x4s and and mounted my amp to it. got rid of the sound.
RIP 4/23/12
...lets not forget, the 88" Z31 turbo, are my dailys
I may have bad news for you my friend, I had a JL awhile back and the same thing happened to be, it's blown. Not fully mind you, but it's damaged and WILL get worse over time. JL subs are VERY sensitive to improper tuning, I tried pushing my tune too much and this is what happened. It happens when over powering it and/or turning up the bass boost too much on the amp, sorry to give you the bad newsOriginally posted by itsm3omg View PostI have a JL Audio 12' and today while I was playing it, it started to make a weird humming noise and it still hits beats when I play it pass volume 8 but anything below volume 8 I can hear the annoying noise? Any thoughts on it
Last edited by dj_ender; 06-20-2011, 06:44 PM.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
mhm I kinda have the same problem but its coming out of my car speakers and not the suibs .... I been looking into this issue and i decide to purchase a noise filter hopefully it solves my problem ill update at a later time since im waiting on it to arrive in the mail...
91 lx that I call Cinnamon
