common rattling
    common rattling
    Ok I'm putting a system in my cb what are some of the things that usually rattle in our cbs. I know the license plate rattles.
    1992 Accord EX Coupe >http://www.cb7tuner.com/vbb/showthre...00#post3060200
    Originally posted by keepinitclean
    I give it 2 weeks before you sell it.
    It's different for every car but the rear deck and I believe the high brake light rattles and the trunk lid. You'll just have to listen yourself and treat them one at a time.
    YouTube Clicky!!
      my entire car rattles. sunroof, trunk, doors, windows, everything.
      COUPE K24
        personaly i dynamated my whole trunk and rear deck. spray foamed it up a little and it sounds way better. it all dependss on you setup. i have always pushed atleast 1k watts rms. kicker amps. put ur system in and see what needs 2 be matted.
          Ya I've got the same issue. I've used dynamat on the rear deck and the trunk lid and anywhere else I could put it but still rattles like crazy. I put my jack in a cloth bag as well as the tire iron and handle, cause that all rattles to shit too. the spare rattles a bit too and so does the complete rear deck even after the dynamat. All the metal back there seems really flexible so I think I'm gonna try re-enforcing the rear deck with some mdf or something to stop the crazy vibration. I also put foam tape on the back of anything I could unbolt or unscrew and that seemed to help too.
            My tail-lights, third eye, my rear deck speakers are constantly vibrating loose (you might want to throw a piece of mat underneath them, I've seen guys pushing them everytime the subs hit; one of my buddies thought it was cool to see the cloth puff up every time his bass hit. Guess who bought new speakers a week later? ).
              When I had my sedan I dynamatted the 4 doors, whole roof, trunk lid, left and right trunk panels, and rear package tray, and a peice cut out the same size of the license plate.
              Like visualpoet said about his friend and his rear speakers you should cover them somehow.
              I ended up using the left over tubs from butter and dynamatted them inside and out.
              I also cut 2 - 6 1/2" holes on both sides of the third breaklight for the bass to get through.
              I had 0 rattles and I had 2 JL audio 12's that where louder than hell.
              Bought from: Jack_Lee, Hondaguy1212, cb7dazz, dannyd, frootloops, ncoutlaw, busak87, Losiracer2, KeeleDesign, 1993ACCORDMAN, gdout90accord, sikz6, Type_G
              Sold to: 1993haccord, samrjr0044, blk91coupe
                My wings the worst lol it has an crack and it just sounds horrable lol.....but it will be gone soon so im not worryed about it raddlin....my plates rattled till i fixed them....but other then that my cars pretty solid.....great stuff works wonders for the trunk lid......and an cheap alt for the plates is flashing its tar based but your plates are out side so youll never smell the tar.....
                My 90 coupe Mr thread....
                http://www.cb7tuner.com/vbb/showthread.php?t=178452
                  My rear window regulator vibrates when my sub kicks in. I opened it up and tightened everything an the vibration is less noticeable. Make sure you don't have any lose screws
                  http://www.cb7tuner.com/vbb/showpost...53&postcount=4
                    An good seal two it will help it from rattling....of corse if its as loud as mine is your better off glueing it shut lol.....
                      those bars in the trunk under the third brake light rattle in my car. i have my sub pointing to the deck so it smacks pretty often.
                        i have also used a product called great stuff in the webbing of the trunk lid, it is an expanding foam used for insulation in houses, just dont go to crazy with it because it can pop the webbing off the trunk lid
                          On my car the only things that rattle are the license plate and the rear view mirror
                          edit: the whole car
                          cb7sk8rdude
                            its usually just the trunk i removed the 2 bars that hold the trunk problem solve they dint work any ways that and license plate the rest dont worry about it things are going to rattle period.
