Rear speaker deck removal and costomization
    Don't know if this should be in the audio threads or the appearance section, but this would more pertain to audio since that's what I want to customize it to.
    ANYWAY......
    How do I take the rear deck out?
    I'd like to put some 8's in it.
    You would have to cut it. Best bet is to throw some 3/4" mdf on top and bolt it down to the metal then seal up the outsides. Or you could just mount the subs under the existing speaker holes. It's easier and alot less work. Cut a nice baffle and mount it under each hole and mount the speaker to the baffle(spacer).
    YouTube Clicky!!
      i would find someone or yourself to build a custom fiberglass molding that is similar to your rear speaker mounts. but have it built to fit your 8's. use existing holes that your old speaker mounts went into. have it tilt a little towards the rear window so you have the bass to bounce off of. i saw this setup in a acura legend. i thought of doing it myself for my ride but i like the big bumps in my trunk.
      RIP 4/23/12...lets not forget, the 88" Z31 turbo, are my dailys
        Would there be a way to cut out the rear deck and still leave enough support for MDF board?
        And also about the two support rods for the trunk lid. Could they be removed without causing damage or anything?
          Don't cut the deck at all. Mount the board under the deck and mount the speakers under the board using the existing speaker holes to vent to the cabin.
          The torsion rods? If you get rid of them your trunk won't have any spring. and you'll have to hold it up with a stick or something
          YouTube Clicky!!
            But won't i need to get rid of the metal that would be blocking me from putting two 8's in?
              Nevermind, I see why I'm confused.
              I'm not just talking about replacing the speakers with 8's...
              I'm talking about having my 6x9's where they usually go and putting two 8's in the middle.... so 4 speakers total in the rear deck.
                Sounds a lil ghetto imo. Take their suggestions. Add to your car. Dont cut away
                  To remove the rear deck - Rip it out.
                  I had very little luck removing it in one piece, you can try, but I doubt your luck after 20+years.
                  MDF swap:
                  My 5.7 LS1 Holden Ute
                    It's not ghetto. It's an IB install. It's been done alot and with larger speakers.
                    If you're going to add 2 subs to the rear deck then you'll have to make holes in the metal. Might as well do 4 8's too and scrap the 6x9's. You'll have to get struts for your trunk cause you'll be getting rid of the spring.
                    Looking at that mdf board, it looks like you can get away with 4 10's Speaking of mdf, you'll have to make one of those too. Along with some deadener for the rattles
                    YouTube Clicky!!
                      4 8's would be cool
                      Trunk struts... where would I find those?
                      MDF swap:
                      I remember seeing this on your MR thread, you actually inspired me to do what I'm doing.
                        Same concept
                        http://www.cb7tuner.com/vbb/showthread.php?t=103315
                        YouTube Clicky!!
                          Hay that works...not what i was thinking but it works
                          My 90 coupe Mr thread....
                          http://www.cb7tuner.com/vbb/showthread.php?t=178452
                            Where is a good place to get MDF board?
                              Home depot, lowes
                              YouTube Clicky!!
