Deep Cycle Battery
    Deep Cycle Battery
    So after no luck in finding an oddessey alt at the junk yard, I've decided to upgrade my battery after my big 3. I saw a kinetic audio battery on sonicelectronix for like 60 bucks. It says it handles 500watts, but doesnt say if its rms or peak.
    About the deep cycle battery, Ive read that they really help alot when it comes to light diming but I know they are also really expensive. Well I went to a battery warehouse by my house today and saw asked about there deep cycle batteries. They have some by the brand Trojan and they have some good deals on them. New one would cost me 105 including tax, but if Im lucky enough to find a refurbished one, i can get it for 32 flat.
    My question is, how do these stack up vs the kinetic audio battery, and vs an optima deep cycle battery?
    Also, this battery is also marine if it matters, and Im either getting this one, or the kinetic, not the optima.
    There's Meany different deep cycle batteries. I personally run kenetic and can say they hold up to what they say they do. I can't say for the other battery you said. I've never owned one. But I'm shure it'll hold up two just not as well. Kenetic rates on rms so 500rms. Hope that helps a little....
    My 90 coupe Mr thread....
    http://www.cb7tuner.com/vbb/showthread.php?t=178452
      Thats good to hear as I am running 500rms. I forgot to mention that this will also be my main battery and not a second battery. IF this trojan deep cycle is actually good, lets say optima good, would it be better than the kinetic?
        If your looking at this one http://www.sonicelectronix.com/item_...B-KHC600B.html it should be OK for a starter battery. It has 1000 cranking amps the other battery you can't run as a starting battery its not made for starting a car. Its basically a energy storage for your amp. You would add it in line to your stock battery.
          Ok thanx. Really appreciate the help
            If you don't want the Optima, you could try Duralast Platinum. They're glass (or fiberglass) batteries.
            MRT
            sneaky motherfucker
              I just purchased a Kinetik KHC1200 from SonicElectronix.com and I am totally satisfied with my purchase.
              PSN ~ Ghostboost03
              Jimm@BavAuto.com
              ~1993 Accord LX
              ~2003 Nissan Maxima GLE
              ~2003.5 Mazdaspeed Protege #1954 - SOLD
                are you using the kinetik battery as the primary battery also or just for the audio?
                '94 CD5 EX F22B1 Automatic
                  Also batteries aren't rated in "watts." That's more of a selling thing that kinetic does.
                  I recommend an AGM (absorbed glass mat) type battery and not the gel like the optima is.
                  The battery may not stop your lights from dimming, fyi.
                  To contribute, I have a diehard platinum battery and its great so far. I haven't really pushed it yet though.
                  YouTube Clicky!!
                    http://www.cb7tuner.com/vbb/showpost...12&postcount=6
                      I like the odyssey battery.......
                      JDM Parts for sale
                        Nice.....But you could easily add a battery or cap,,,,and the cap its self would take the light dim away?I have a big memphis 1000x1 and 3 15's in my truck with a 1fr cap and extra battery and im strong..... no deep cycles,No dim.....I would just add a cap......
                        Only give advice when I know or have done it and it worked
                          I`ve got the Optima red top, serves me well. Ive also got a 1fr cap in between but if I could do it again id go for odyssey probably. Optima was available locally so that was my selling point at the time. Also they're made by interstate.
                            I've tried the optima red and yellow tops, an odyssey model i can't remember and some generic batteries from sears.
                            Red Top Optima has been the best overall performing battery by far. ALWAYS cranks over. Never left me stranded. Fixed the mild light dimming i've experienced with more powerful systems i've had.
                            The Odyssey i tried was cool due to it's size/weight advantages, but seemed to discharge more quickly when left sitting and failed to start the car twice after sitting for relatively short amounts of time.
                              optima red may be good but the yellows are terrible....4 dead within a year and a half
                              SHARPIE ACCORD HERE....
                              http://www.cb7tuner.com/vbb/showthread.php?t=192457
