Originally posted by CB7tom
View Post
Brake Lamp Light Is On
Originally posted by FizzupTK View PostYes Ill Check the brake switch, for some random reason i thought it was behind the pedal.
Originally posted by Dynamic93-408 View PostBrake fluid level. Check that
I had this same punk ass problem with an old CB of mine... I replaced the third brake lamp, brown boxes, brake switch, cleaned all the connections with steel wool... That shit never went off. I finally said fuck all the dumb shit and removed the bulb out of the cluster.
Originally posted by HardInThePaint View PostIt is.
Quit telling him to check his brake fluid he just said it ain't that light.
Having this problem, too. I haven't figured out mine yet, either. Will follow the suggestion of replacing the cluster although mine looks outwardly fine. Very frustrating!
Originally posted by Hmong-cb7tuner View PostI have the same problem, my brake lamp light is on n I checked all the connection and there were great and has no rip or cut, but the light on the trunk, the left side does not work when you push on they brakes, the build are not Burt and the wiring is corrected.
Any clue?
Did your original wiring look bad at all? Having a similar problem but everything looks good from outward appearance. Hope to make another JY run this weekend, so may try and grab a couple of those if that solved your problem.
Originally posted by 93smurf View Posttry replacing the cluster i had the same problem when i got a 91 ex wagon for a parts car i pulled the 160k cluster and put it in my 93 havent had the light come on since.
Originally posted by SEgirl View PostDid your original wiring look bad at all? Having a similar problem but everything looks good from outward appearance. Hope to make another JY run this weekend, so may try and grab a couple of those if that solved your problem.
Got my headlight issue fixed which was a bad ground. That did fix the issue in that all of my lights are working, front and back. However, brake lamp light is still on. I did replace the sensor (brown box thingy) with two that I got from the JY, but that didn't work. I didn't try the box on the right as I don't have replacement for that one, and didn't make it to the JY this past weekend. Will try that and another cluster and see what happens. At least all the lights are working now. Glad yours got fixed.
Originally posted by 93smurf View Posteverything was fine being my led bar on my spoiler was working i figured it had to be something weird my original cluster 250+k it was never on but speedo stopped working so i swapped a 93 lx cluster speedo worked but 3rd brake light was on as soon as i tapped the brakes getting out of the driveway. i pulled the 160K cluster and decided to swap for the hell of it and been 3 weeks since no 3rd brake light. so im convinced it was the cluster.
After thinking about it, I might just have one around here. I did have to replace a broken tail light when I first got the car, and the replacement one I got came with a cluster. Can't remember if I kept the original in the car, or used the one with the replacement. Have to dig around and see if I still have it. Plus, all my lights in the green SE are working properly, so I can always pull one from it and use it to test.
Originally posted by 93smurf View Postdefinatly gotta get a diffrent cluster if u were closer id send you one. got tons of them but it's getting harder to come across the 5 spd ones for me.
It is like if that light on dash doesn't come on something must be wrong. All three of my Accords have this problem. I checked every lamp all third cyclops lights and still nothing. I just couldn't have 3 bad clusters. In fact I know it's not a cluster issue; on wagon barely used and driven by old people.
I'm thinking it is a wear problem..but all lamps work. Have you noticed that when you turn on the car and you are parked with no foot on brakes...all the self diagnostics on dash go on then off leaving ONLY the brake lamp out light on? That tells me it could be a sensor or contact...am I right? SO where is that little shit?Last edited by SilverShadow; 01-29-2013, 01:49 PM.
Old wagon - Silver '92 LX Wagon - Steve (Shadow)- STOLEN ON LABOR DAY 2012
New wagon- White '92 LX Wagon on 1/3/13 (Frostbite)
2000 EX Coupe - Joe -
www.AccordWagonClub.com
My Facebook Site - ACCORDOBSESSION
lol- I thought the cluster you were talking about was the wire cluster that is on the back of the actual light itself (where the bulbs plug in). I did not think of the cluster in the instrument panel.
Thanks for the suggestion if I decide to go after the cluster you're talking about. I may give it a rest for a couple of weeks as I'd actually like to enjoy taking the car out for a drive, instead of it being in pieces all the time.
Originally posted by 93smurf View Postjust be careful with it i find it's a ton easier to remove steering wheel,washer and signal switches before pulling it out.
