91 ex gauges stopped working
    When I got my car the speedometer didn't work but all the other gauges did. Well today I got to looking and seen that the vss was unplugged, so I plugged it in and started my car up and went to drive it to see if the speedo started working. It didn't so I know that I need a new vss but now my tach fuel and temp gauges don't work along with my radiator fan. All the fuses are good I unplugged the vss unhooked the battery and still nothing. If anyone could help me out I'd be really happy.
    Check the thermostat ground for any corrosion/damage.
    My 5.7 LS1 Holden Ute
      check all your grounds . if there is some sorta corrosion clean it up a bit with a fine sand paper . also if you took apart your cluster might wana check your pigtails , just some stuff to look for
