RF speaker works intermittently...
    The previous owner put in some Sony speakers in the front doors that are in great shape. I tested and inspected them so I know that they are not the cause. All connections inside the door appear solid. So my question is... Could the speaker be going out due to a failed internal component with the factory head unit? Not sure if this is a common problem. If not, maybe a ground wire that tends to fail? One last bit, it comes on USUALLY if I crank up the volume or hit a hard bump. Makes me think the circuit it open somewhere if not a failed component.
    P.S. - I am very proficient with soldering and circuitry engineering but of course, it works whenever I try to test it and I have not yet felt like opening up the head unit yet.
    Originally posted by Rezz View Post
    I tested and inspected them so I know that they are not the cause. One last bit, it comes on USUALLY if I crank up the volume or hit a hard bump.
    Sounds like a faulty speaker coil.
    How did you inspect them?
    Really simple way to test - Swap the speakers.
    If it still happens on the opposite door - The speaker is at fault.
    If it still happens on the same door - The wiring/headunit is at fault.
    My 5.7 LS1 Holden Ute
      Broken solder joint in the hu?
      If you tested them properly, you would definitely be able to tell if your speaker was cooked.
      I don't think your speaker is grounded...
      To test the hu just tap it with a rubber mallet on the chassis. It will simulate going over hard bumps.
      YouTube Clicky!!
        Yup. Looks like your best bet is to swap your speakers and see if the problem has moved to the other side.
          I tested them by swapping them side to side (like someone mentioned). The fault was still on the right side. The ever perplexing part that I forgot to mention is that IF the speaker is NOT working and I turn the volume all the way down, it remains the only speaker that BARELY remains audible... I would think a bad ground would be ruled out by that but could be mistaken.
