Ok so i have 93 accord ex coupe that is completely stock and most of my engine bay is clean smooth and just all around nice looking but all of the wiring, brackets, and connections are a huge eyesore so im about to start tucking and cleaning everything up.
my questions are if i move my battery to my trunk will the increased distance effect anything? is there anything i need to do to boost it or is the distance so short that it wont matter?
also ive got an f22a6 engine and there are a couple ground wires near my power staring pump, one smaller wire from the valve cover to the power steering bracket and from the bracket to the body.. do these grounds have to be located here?
lastly, if my battery is moved to the trunk is it necessary to vent the box i have to put it in? i understand some tracks require it? that doesnt matter to me my question is do batteries still leak gasses? or is that mostly a thing of the past?
so I'm in the process of fixing his mistakes. When I did this to my Mk2 GTI it was commonplace to use 0 awg welding cable, as the copper coil of the wire is more efficient than standard battery cable and it's said to be better insulated. I'll either be doing that to fix my slow battery drain or I'll be bringing the battery back up front.
