Ever since i did my 5 spd Conversion on my 91 Coupe The alarm Doesnt Work even after we hooked everything back up . Now every wire is where its supposed to be along with the ground.. If neone has ne suggestions i would appreciate it mahalo.
Alarm Problem
obviously you didnt hook it up right.
check the power wire at the alarm to see if the fuse is blown...also to see if your connections are solid.
sometimes the antenna wire can be damaged or not plugged in all the way so check that as well.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Clifford, DEI, Avital, Alpine, etc....
