Alarm Problem
    Alarm Problem
    Ever since i did my 5 spd Conversion on my 91 Coupe The alarm Doesnt Work even after we hooked everything back up . Now every wire is where its supposed to be along with the ground.. If neone has ne suggestions i would appreciate it mahalo.
    I-SR 6
    obviously you didnt hook it up right.
    check the power wire at the alarm to see if the fuse is blown...also to see if your connections are solid.
    sometimes the antenna wire can be damaged or not plugged in all the way so check that as well.
    Retro!
    Hater
      What alarm do you have.... Clifford, DEI, Avital, Alpine, etc....
      1992 Accord LX - SOLD
        what kind of problems are you haveing. does it arm with the remote? or it wont arm within the 30 or so seconds by itself. if its the latter you might want to check if its in valet mode. sometimes it's just the stupid little things that get looked over. check on that and see what happens.
