Component Crossover
    Originally posted by CA1978
    I believe it is called a hole saw it will cut through the door panel easily but do not try to go throught the metal. It attaches to a drill. I have one which is what I will be using once I run my wires my kickers require a 2.5 inch whole.
    Yea I took the door panels off of mine to cut the holes. And make sure you measure the tweeter vs. the saw...you don't wanna cut too much. I have nothing holding my tweeters in but the fact that the hole is a little smaller than the tweeter.
    Originally posted by lordoja
      Luckily for me my tweeters have trim pieces and vaious mounts.
        Originally posted by pickandpull@hot
        wow thats a good idea, never thought of putting the crossover there. i actually put the crossover inside the door. theres a spot where you could bracket the crossover to the door itself. i double check it to see if the windows and the bar hits it, but it doesnt. but hondatuner is probably a better idea. less work.
        i also put my crossover in the same spot, but i wrapped the crossover in the plastic bag that came with the crossover and used some dynamat to stick it to the door.
          i actually put my crossover behind my door panel and just found the spot that it would fit but it made it pretty easy since i have a dx model
          Everything done on this baby is all by me, NOT one thing done by a shop or store
          My myspace hit me up
