i was wondering if my cb7 came with a power antenna.
its a 92 LX. im not sure because the actual antenna can move up and down if i push/pull on it but when i turn the radio on/off it dosnt move. the previous owner installed an aftermarket headunit so idk if he wired it wrong or anything.
im going to check tomorrow when i have some daylight to see if its all wired correctly.
but does anyone know if i have a power antenna?
i know it sounds dumb but this is my first car...
thanks.
thanks.
) and i could play cds and stuff perfectly fine, but the radio reception sucked -- i took the head unit out again and realize that I forgot to plug in this black wire that looks like a large microphone or headphone jack (not 3.5mm, but whatever that large one is). so i plugged that into the headunit just out of curiousity and low and behold...the antenna powered up whenever i turned on the radio --
BUT now my stock antenna is replaced with an aftermarket rubber antenna. reception is better and it wont break as easily as the stock powered, and plus i looks better (doesnt have to power up and down).
