I got a new h/u and tried to install it. After installing it everything, I tested it out b4 putting the dash back together. After I finished I started the car and tried to turn on the h/u but then it didnt turn on. Also it caused me auto seatbelts not to work either. I did everything right and plugged everything in correctly. What could be the problem that caused this? Please help!!! And info is greatly appreciated.
Need halp ASAP!!!! Please
turn yer car ON ...not running just ON
use your simple and cheap CIRCUIT TESTER which has a bulb in the handle, a needle point and a cable with a roach clip on the end....
clip the roach clip to a very good ground (unpainted metal...scraoe some paint off the brake pedal METAL part and then use the needle point on the tester to probe the fuses one by one.
good luck dudeYEP. I AM Canadian.
1990 Accord EX 220,000 KM. Essentially stock with 15" alloys and chin spoiler added. K&N filter and Bosch plugs. ICE COLD A/C which I love!
1992 white EX 4 dr, 5 spd. (602,000 Kms and I JUST RETIRED IT. SO SAD!) DEC 9TH, 2005 - MAY 31, 2012. I added 229,000 kms to it. Great car!
or what Erik said.....pull the fuse box cover....read each sqaure on the inside of the cover....it tells you where and what each fuse is for(along with its power rating)
Pull the ones that apply to the general area of stuff not working and look at the top of the fuse(the opposite end of where it plugs in)
It will have a metal tab...if its broken or burnt it probably should be replaced.
Thats about all i can think of.
I blew my 15a fuse under the hood reinstalling my pass side visor and the following stopped working:
hazards, int setting on wipers, dome light, radio.
So just get in there and check all the fuses if you have to and if they are all fine time to pull that radio out....it might be grounding out somewhere.
I taped all the loose ends so nothing should be touching. It was working when i tested it out at the beginning but when i screwed everything back up and tested it again it stopped working. I even changed the fuse in the kicker panel but nothing happened. Does anyone know it the fuse to the radio is the same as the auto seatbelts?
Stereo Wiring Information:
Constant 12V+ White/Yellow
Switched 12V+ Yellow/Red
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Trigger Yellow/White
Antenna Left Rear
Front Speakers 6 1/2" Doors
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers 6 1/2" Rear Deck
Left Rear (+) Gray/White
Left Rear (-) Blue/Yellow
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
Alarm Wiring Information:
Constant 12V+ White Ignition Switch Harness
Starter White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Ignition 2 White/Black Ignition Switch Harness
Accessory Yellow Ignition Switch Harness
Tach Blue Distributor
Neutral Safety Wire Green/White 12 Pin Connector Gear Select Switch
Brake Switch Green/White Brake Switch
Trunk Release Orange/Silver Dots in Harness Driver's Front Door Sill
Trunk Pin Green/Black (-) Above Hood Release Green Connector
Parking Lights Red/Black Fuse Panel in Driver's Kick Panel
Head Lamp Blue/Red (-) Light Switch
Hood Pin n/a
Factory Disarm n/a
Door Trigger Black/White (-) Above Hood Release Brown Connector
Door Lock Black/White (-) Under carpet below Fuse 2 Pin Connector
Door Unlock Black/Red (-)
Horn Wire Light Green/Blue (-) Steering Column
Windows Up LF=Red/Blue, RF=Blue/Yellow
Windows Down LF=Red/Yellow, RF=Yellow/Green
http://www.mycb7.com/bb/viewtopic.php?t=44
