what is the difference between a ported subwoofer box and sealed subwoofer box? is one louder than the other? thanks for any info
subwoofer box
Originally posted by busak87what is the difference between a ported subwoofer box and sealed subwoofer box? is one louder than the other? thanks for any info
the ported box depends on how the box is. if its just a box with a hole on the side. its not really gonna matter. but if its made in a way that the air travels a cerain way to release the air makes the sub pound harder.DONT SWEAT THE TECHNIQUE
That's a lot of information to ask for, but this link should help you out.
http://www.carstereo.com/help/Articles.cfm?id=33
Ported boxes have an air port that is "tuned" to a certain frequency. The enclosure will be louder at that specific frequency, which is why most ported boxes will "boom" when played with hip hop music. Most of that music is heavy in the 32-45Hz range, which is where most box ports are typically tuned to. A sealed box will be better for an SQ setup, as it will have a much flatter frequency curve. It will not really be particularly strong in any area.
Edit - A sealed enclosure will be extend further (play lower frequencies) than a ported enclosure. This is another reason it's preferred for SQ competition.Last edited by Camurai; 11-26-2007, 08:47 PM.~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
Project Deerslayer
UPDATE: DEER - 2, CB7 - 0
'93 EX 5-speed coupe
Short ram intake
Tenrai Himoto catback
Smashed front end
Originally posted by CamuraiPorted boxes have an air port that is "tuned" to a certain frequency. The enclosure will be louder at that specific frequency, which is why most ported boxes will "boom" when played with hip hop music. Most of that music is heavy in the 32-45Hz range, which is where most box ports are typically tuned to. A sealed box will be better for an SQ setup, as it will have a much flatter frequency curve. It will not really be particularly strong in any area.
Edit - A sealed enclosure will be extend further (play lower frequencies) than a ported enclosure. This is another reason it's preferred for SQ competition.Members Ride sold...
It was a little bit of both. I've tried both types of enclosures in vehicles, and found the frequency response was a lot flatter with a sealed enclosure, and sealed boxes extend a little lower. If you want to measure the SPL response wave with a microphone and the proper software to prove it, knock yourself out. I've done it before. Ported boxes will have a nice big bump at their tuned frequency.
When I was actually into the scene (granted, this was awhile ago) most people running SQ competition were using sealed enclosures because SQ judging at the time was partially based on a response curve. Not strictly the way you'd expect the "Sound Quality" class to be judged, I'll grant you, but that's the way they were doing it. Typically, the systems set up for a smooth response curve sound like ass. At the time, I thought "SQ" was sort of an oxymoronic term, considering the way it was being measured. Should have been called something like "Scientific Measurement Class."
Anyway, if I wanted tighter bass and deeper extension, I'd run a sealed system. I prefer a little more bump, so I typically run a slot-ported enclosure tuned to about 38Hz.~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
Project Deerslayer
Short ram intake
Smashed front end
