I was just wondering f it's bad for the car to race in d3 up until u need to shift into d4. and what speed do u need to shift into d4?
Transmission question...
If you want people to help you out, please use proper grammer because I did not even understand what your question
Bahaha, yes concentrate hard, because it is very tricky racing and automaticOriginally posted by deevergote View PostIt's not bad for it... but an automatic is fastest when you let it shift itself. Just put it in D4 and concentrate on your gas pedal.
I've only gotten it to about 60-65 in d3. Are you sure it's not faster, because it seems like it has way more pull and jump of the line.Originally posted by cb7_ex_coupe View Postits not the fastest way but u kan...and im not sure on the speed...you would feel it tho...the car kinda would feel like its not pulling anymore...
It does have more pull off the line than it will at 60-65. It takes exponentially more power to cause the same increase in acceleration at 60 than it does at 0. Trust us, the TCU is going to shift your ride far more efficently than you are going to. Honda programmed it to shift at the right time under all types of acceleration.
If I learn to properly modulate my gas pedal, you think i'd be able to beat the 17.6 second quarter mile time my car is rated for? And how do yyou properly modulate it?Originally posted by deevergote View PostProperly modulating the gas pedal takes some skill... I learned that with my GTP! It's not as involved as driving a manual... but it's not all just press and go.
) in the past cause of that.
