what trany besides h22 would go good hith the h22 gear ratio wise
trany
Do you mean with the H22 engine? and the same ratio as the H22 box?
Boxes that will fit H22 engine - F20/F22, H22, H23
My 5.7 LS1 Holden Ute
Yeah, if his H22 gears are too long, the F22 gears will be WAY too long!Originally posted by breeziebabyyyI'm not 100% on this but I've heard that the f22 tranny will work good because it has a longer ratio for shifting or something like that
The USDM H22 transmission has slightly shorter gearing than the JDM. I don't know if the F20B transmission is shorter, but it may be. I can't find the ratios anywhere to confirm.
You don't want to go too short... your car will be a pain to drive, and may actually be slower.
yes going to short will make me fall out of v-tec but i plan to tune and lower my v-tec so it will all work outOriginally posted by deevergoteYeah, if his H22 gears are too long, the F22 gears will be WAY too long!
The jdm accord euro r and the edm accord type r have the shortest gear ratios stock, it just depends on wht 5th gear you want.
Accord Euro R Accord Type R
1st 3.285 1st 3.285
2nd 2.090 2nd 2.090
3rd 1.481 3rd 1.481
4th 1.071 4th 1.071
5th 0.812 5th 0.870
Final 4.266 Final 4.266Last edited by 90goldcoupe; 03-17-2008, 12:25 AM.
Chipped ECU or VAFC. Setting vtec too low will not give you any benefit. I had mine set at 4500 once not that great but that was when i had the F. I also set it at 6700 once just for the hell of it lol that was fun. But now I have it set at 5000 but really when you tune you want the crossover to be smooth. Anyway as mentioned above the f20b trans is closer geared than the h22a. Cruising is gonna fail but the closer gearing will allow quicker acceleration. If you can find teh ATR trans in europe thats one of the closest H series geared trans I have seen.Originally posted by deevergoteActually, going short will not make you fall out of vtec.. Long gears will.
Short gears will just make you rip through your powerband before you really go anywhere... as well as shift an extra time while racing.
And how do you plan on tuning and lowering the vtec?
vafc-II chip and tune from revlineOriginally posted by deevergoteActually, going short will not make you fall out of vtec.. Long gears will.
Not 100% but i have heard of people using the H23 tranny and having good luck with this, also i think the brand name is quarter something or other but they make a HtoB adapter where you can use a B series tranny.2002 Mazda B-3000- Daily Driver
1991 Honda Accord LX-Sold
2000 Jeep Wrangler-SOLD
1985 BMW-Autocrosser-SOLD
1993 Honda Civic Hatchback-R.I.P
H2B is pointless on accords unless its for racing.
