5w20!?!??!
    ive always used 5w-20 in the winter and 10w-30 in the summer, i mean my auto teacher told us that the weight kinda corresponds to the weather and i live in jersey so in winter gets below 20 alot and sumetimes into the single digits and at nite time even in to the negative numbers, then when summer rolls around it gets into the 90s sometimes 100s so i then use the thicker oil...correct me if thats wrong?
    To some people, a car is a car. But to people like us, its so much more than just a car. Its a getaway. Its our hiding spot. Its our comfort. Its an extension of ourselves.
      i've used 10w30 full synthetics ever since i've owned my cb. never had problems, so i never thought of trying anythinig else
        I had a friend at work that use to be a mechanic. He said that in Texas, 10w30 is recommended. I've seen a new oil on the market but know sure if its new or not but 0w30? Never heard of it.
        F22A1 = Now, NA : Soon, Turbo
        My Member's Thread
        Arcadia Green #14
          I beleive most small engine hybrid cars use the 0W oil.
          For example the Honda Insight which uses 0w20 oil.
          1996 Honda Civic LX 2009-2012
          2012 Kia Optima LX 2012-2013
            Why do you feel you need thicker oil in the summer?
            2003 Maxima SE Titanium Edition
            1993 Suzuki GSX1100F 136bhp
              if your car has a leak...the way to resolve any issues it not thicker/higher vicsosity oil...
              fix the leak...problem solved.
              if you put in synthetic and you notice leaks...the issue is not with synthetic oil...it is the leak.
              Fix the leak, use factory recommended oil viscosity
              ____
                My engine runs the same temp in summer as in winter, cold starting on the other hand can be an issue but synthetics handle that nicely. Without an oil pressure gauge it's hard to tell if your oil is too heavy or too thin.
                  I've always used 10-30 in the cold, and 5-30 when it's warm. Heard 5w's thicker than 10w. Works out though, but once the car's back, I'ma definitely go synthetic. Made a difference in the last engine.
                  98' Mustang 3V Swap
                  11' VW CC R36
                    All new Hondas run 5w20, which is whats in my car. DO NOT RUN OW20, Ow-- is too thin for your engine. it is strickly for hybrid engine use! Someone asked why you want to run 10w30 in the summer time. 10w30 is a thicker oil and as the weather/temp warms your viscosity (sp?) breaks down and you would want a heavier oil.
                      Oh, I see.
                      Yes, I asked why you'd want a thicker oil.
                      Do you have any idea what the 10W (or 0W, for that matter) means?
                      My thermostat controls the running temp of my car. The running temp of my car is the same in winter and summer.
                      I've used 0W-30 in my Honda, Audi and Nissan without issue.
                        your car runs at mostly the same temp once it has reached operating temp.
                        But we have the oil ratings we have (5w-30, 10w-30) because of cold starts. Yes I know there is more to it then JUST that but the reason for that range of viscosity is due to the engine being MUCH MUCH colder when it first starts...keep in mind...while your engine is not "cold" to the touch per say, in relation to operating temp it is cold. Now if you are in very cold climates you have to add to that.
                        ____
                          I used 5w20 because i got a civic
                            go synthetic 5W-50
                            Don't listen to these guys talk about what they think is best... go do some RESEARCH about the truth of what oil is.. especially "synthetic" and come up with your own conclusion.
                            go to http://www.synlube.com/publicat.htm and check out what they say....
                            Now I am not saying spend $50 on real synthetic oil but look at the science of how oil changes as it is being used. Look at what additives are used. Learn what it means to say "synthetic' on a bottle. learn about how they reuse motor oil. There is so much behind this besides just asking what type of oil should I use... read this website and some others and come up with your own decision.
                            and BTW your engine LOOOOOVES thick oil! these dudes who think thinner is better or think that ambient temperature doesn't matter should not be taken seriously!
                            AD5OS
                            FOLDING@home
                              I dont mean to threadjack, but I heard high mileage engines could use 20w50. Is that true?
                              I have used 10w30 since I had the car and it has 272k.
                              My CB For Sale
                                There's a website called SmartGas that has tips for higher mpg, in it they talk about oil and thin oil is not recomended. They're saying 20w50 and 15w40 is the way to go, adding maybe one quart of synthetic 20w50 to the rest. I wasn't too sure about this until I read comments on another site from a del sol owner who was burning a tank a day going to college. He did just what they said and it did increase his milege, I beleive it was 2-3 mpg more just from the oil. I want to hook up my new oil pressure gauge before I go to heavier oil though, I'd like to see the difference and make sure it doesn't get too high, hate to lose a crank seal or something.
