My driver side window is going down about 2 inches then it stops and there is a grinding and clicking noise. Anyone know what this problem is and how to fix it? Im stuck, I just spent all afternoon trying to figure it out and cant. Open to any suggestions, dont want to take it to the shop again.
Window Problem
Originally posted by TypeGi'd try lubing up the run channels with silicone. other than that, it's probably the window regulator. later."form follows function."
Louis Sullivan
Originally posted by Chan_ManLike TypeG said It's your window regulator. All Honda's especially cb7's are notorious for having window regulator problems. Go to the junkyard and get a replacement because dealerships will charge you way overprice for a new one.
^^click it or ticket^^
I have to install mine because it's been raining so much that I don't want to start and get rained out halfway through."I'm a dude playing a dude, disguised as another dude"
"That if thou shalt confess with thy mouth the Lord Jesus, and shalt believe in thine heart that God hath raised him from the dead, thou shalt be saved."
Romans 10:9
><((((º>
there is a semi circle gear full of teeth that the motor moves up and down. Like a starter to a flywheel.
http://cgi.ebay.com/ebaymotors/1990-...3286.m20.l1116
that's what it looks like.
the teeth wear out over time (that's why your mother always yelled at you as a kid when you would push the window switch up and down over and over again)
I recommend Dr. Auto Parts on eBay. It's under 50 shipped and works fine
im having problems with my rear passenger window also the only problem is my cb7 is a dx and is hard to find parts for it the window goes down and i believe is out of track nobody that i have talk to know how to fix it or know was wrong with it... it'll suck if i have to take it to the Honda dealership to get it fixed
Originally posted by HondaMamiim having problems with my rear passenger window also the only problem is my cb7 is a dx and is hard to find parts for it the window goes down and i believe is out of track nobody that i have talk to know how to fix it or know was wrong with it... it'll suck if i have to take it to the Honda dealership to get it fixed
It'd be worth it, it takes a matter of seconds to take off your panel, and visually inspect the guts to see if the window's off track, or some guide is broken.
I am having problems with my windows as well. For the thriftier of the users with sedans, would it be possible to swap the from and rear tracks out? The drivers window goes down all the way, but its unreliable and slow as hell. Or is changing it a challenging job that is easier to just order parts for and do once?
sometimes the regulator comes apart, making the window get stuck
93 Accord LX Sedan (sold)
Originally posted by DobermannI am having problems with my windows as well. For the thriftier of the users with sedans, would it be possible to swap the from and rear tracks out? The drivers window goes down all the way, but its unreliable and slow as hell. Or is changing it a challenging job that is easier to just order parts for and do once?
If so, they are different tracks I believe. It is worth it to buy a new one. It is semi difficult at first, but once you do it the first time, it is a snap.
