As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
Window Problem
    Accessing the Regulator
    How do I get to the regulator? I already have the door panel removed. Can I remove the inner metal door, or do I have to work through that tight ass opening at the bottom of the door?
      there should be a wide hole at the bottom. Roll the window down as far as you can and take the two 10mm bolts off of the window, then take the window out, and take the seven 10mm bolts holding the regulator to the door frame, and collapse the regulator, and take it out through the bottom hole
      ^^click it or ticket^^
        Originally posted by CB7lx91
        my best bet is that the regulator was not built to support a human being's weight...only a window pane. Probably jammed the gears, or broke some teeth.
        That's my best guess
        yea that's what i was thinking when i took the panel off since is a DX all you see is wires... wish anybody can help me fix it it sucks if i really have to take it to the Honda dealer
        http://profile.myspace.com/index.cfm...ndid=107733305
          ? the panel for an DX ...is there anyway it will come out to get more view of was goin on inside of the panel i try to see if there is any bolts there arent none i riped the cover and that's as far as i can go
