As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
Need Car Help Plz!!!!
    I Was Driving, The Car Was Runnning Smooth And Clean,
    But When I Got Home And Wanted To Park It Was Like Wanting To Turn Off And It Did,
    Tried To Turn It On Again But Wouldnt, Now It Doesnt Want To At All, I Changed The Ignition Coill But Still Nothing
    This Has Never Happened To Me Until Now Idk Wats Up With The Car
    Any Help Plz
    I Need The Car For Work Now I Dont Go To Work Cause Of Car
    Plz Help Me
    IT MAY BE AUTO BUT IT SURE RUNS FAST FOR A F22A6
    not to make you seem like an idiot, but do you have any gas in it?
    also please don't type in all caps, the server changes it to the first letter of every word being capitalized, which can annoy some people.
    Did you check the ignitor itself?
    ^^click it or ticket^^
      Main Relay?
      NEW PSN
      H22wagon
      New project. 95 EG HB H22
      RIP
        well of course it does have gas, i turn ignition on and it just doesnt wanna turn over. i havent checked the igniter yet, or the main relay, where are them exactly at
        it just happened out of no where its like it wont start anymore
          yes it does have gas more than half,
          this has never happened to me b4,
          the ignitor where is that located exactly and the main relay is that a big problem that might be it or no?
          all lights turn on everything it cranks but wont turn over,
          sometimes when i turn the car on it turns off right away like if i were to turn the car off my self then i turn it back on and fires up fast with out a crank
            Was it a Hot day out? Might be the main relay, not to hard of a fix.. theres a DIY ( do it yourself) in the DIY section. I would get you a link buy my mouse died
            R.I.P Mulberry Red Pearl 90'ex
            SASKCB7 Tuner
            Searching for a CB7, within 1000m of me
              yea that would be koo man,
              but idk if was kinda hot, i live in inglewood like close to the beach soo its hot around here but i was down at hollywood soo its hot over there also,that thing just happened. what do u think might be it,?
              i cahnged the coil that wasnt it, soo idk what should i go for now, it cranks and cranks but no start at all,
              can u help me out here that may have experience with this problem
                Eventhough you changed the ignition coil other parts will be culprit..
                Anyway , how does it die? Sputter type or just shut off like switch off?
                1996 Honda Civic LX 2009-2012
                2012 Kia Optima LX 2012-2013
                  well is that all that you have checked? turn the car onto the on position without cranking it, see if you hear the fuel pump priming. If not either a bad pump or bad relay. Also check for spark on all your plugs. I know u just changed ur coil but it doesnt cost you anything to check.
                    yea i turn to the ignition lights and everything and i hear the fuel pump turn on, i tried to turn the car on but it just cranks but doesnt turn on.it has gas more than half,
                    like b4 this happened sometimes when i turned it on it turned on then shut off completely then turned back on, idk if thats ignition problem or not,this thing just happened yesterday and just wont turn on anymore, idk if its the ignition module that just burned out after awhile of driving over years,i never changed that or the main relay,
                    soo any help!
                      soo any help!
                      So it does not sputter when dying?
                      If so , yes it's the ignitor in the distributor. The circuitry got fried and when it get's hot it dies just like that. When it's cold it works isn't it?
                      Happened to me weeks ago , my igniter died because I had oil going into it and fixed the problem by replacing the whole distributor assembly.
                        well the car hasnt turned on since yesterday, right now i went outside tried to tunn it on again but nothing just crank and crank. but no start,
                        maybe the ignition module just got fried or the main relay isnt giving spark or anything
                        idk i just wanna fix this problem, i keep my car in good shape tune ups here and there when it needs it and yea,
                          Pull out the main relay and check for any cracks on the solder points.
                            is that hard to do and where is it located a picture would help, i never done anything with ignition b4 soo i am new to it i guess
