Need Car Help Plz!!!!
    thankx alot that helps soo much.imma try that thing tomorrow, but i think its better to buy a new one and have the old one fixed and for backup correct?
    but hopefully the main relay is the problem here, when i turn my ignition on its normal no blinking lights soo thats good no check engine light that would be ***....
    but hopefully this main relay would fix my problem,
    if not that if might be umm ignition module, cause it cranks but no start
    IT MAY BE AUTO BUT IT SURE RUNS FAST FOR A F22A6
      Fix the old first because new one run atleast $60.
      It's up to you, my shoes would go for new one.
      1996 Honda Civic LX 2009-2012
      2012 Kia Optima LX 2012-2013
        well i think i would try to fix the old one first to see if its that or not, if its not that then it might be the ignition module thing,
        but u just sauther the silver points like saughter on top of it and thats it right,?
        like drop a new dot on aluminum?
          Yup , cover the cracks. Be careful not to solder 2 points in one.
            koo soo thats gonna be my problem correct????
            cause it just wont turn on anymore, soo?
            hmm idk man i just wanna fix this problem and cruise on my car,
              It should.
              Solder it then if it still does not work , check your igniter.
                yea that was gonna be my next thing to check out if this doesnt work,
                and if that was it, imma change fuel filter and new car and rotor might as well right
                well yea hopefully man thats it right there,
                i will fucking run down the block if thats it, if not umm idk what ill do
                  Trust me it's either main relay or ignitor. Happened to me weeks ago. My car died just like that while running on the freeway 75MPH. When it shut off the traffic started going slow and in the nick of time I have pulled over and stopped in time. We don't get power brakes when the car shut's off. Turned out it was my igniter.
                    koo well hopefully its one of those 2 and nothing else big
                      Let us know the update after you got it done.
                      Good luck.
                        bump... so did it fire?
                        -SPADED93
