so my car has been overheating for a while now. i tried all sorts of things. i bled the system many times, check the coolant levels, made sure the thermostat was installed correctly and heat it up to make sure it opens, etc. however, when my engine warms up, pressure builds up in the lower radiator hose. the lower hose remains fairly cold, but the upper one gets really hot. when the car is all warmed up and i drive it around a bit, usually the pressure becomes so great that the radiator cap begins to leak.
what i want to know is what else could i look into to find the solution. if worse comes to worse, i may just pull the engine and start from the inside.
possible water pump failure? i am open to all suggestions.
