no fuel to my engine
    my car has been sittng for 9 months, and now i have no fuel at te fuel rail in my car. i checked the fuel pump and i know it works. i jump the pump and i hear it on, i have put gas in the tank. but still no fual at the rail. i think i will change the fuel filter. and their is no leaks any where in the fuel line. so any ideas
    Check the filter first, But if the pump is coming on then u should have fuel at the rail, Even if the filter is clogged you should get something atleast. Are you sure the pump is coming on fully?
      also check the injectors
      The most influential people have influential friends i have none but peer pressure!!!
        Is the pump priming when you first turn the key on? If not, its prob your main relay.
        My 5.7 LS1 Holden Ute
          pretty sure its a fuel pump issue..
          my old truck did that..when they had it sitting..
          fuel pump was weird..
          Ride: 2002 Lexus IS300
            the main relay is not sending power to the fuel pump. so i jump the wire and send power to the pump. i hear it come on. also i know the pump work because u dropped the tank and took it out to clean the gas that was in their. and while it was out i tested the pump, and it came on. right now i am trying to change the fuel filter but its raining so it will have to wait till tomorrow. and i took the line off the fuel rail to see if any fuel comes out. but the line is bone dry when i crank the car and jump the pump.
              Where in Queens are you located? This rain is pissin me off also.
                i live in queens village. and today which is sunday was no better got cold real fast
