would a 90-91 cpu go into a 92-93? computer
cpu
Yes, but it depends on which engine you have. If you are taking the ecu from a F22A1 or F22A4 (ECU code PT3) and attaching it to an A1 or A4, then you are fine. The exception is if you are taking an ECU from an A1 or A4 and running a F22A6 (ECU code PT6), which is different, and needs the PT6 ECU.1992 Prelude S w/swapped H22A
