One out of a hundred times I go to start my car, it doesn't want to turn over. It seems to be only when the engine is warmed up. I'll try it a couple more times (does the same thing), then wait about one minute. Then it'll start right up. What the hell? It's not the starter because it's been doing this for several years now and I've replaced the starter in that time. Any ideas?
Inconsistant Starting
Originally posted by CB7 FanaticOne out of a hundred times I go to start my car, it doesn't want to turn over. It seems to be only when the engine is warmed up. I'll try it a couple more times (does the same thing), then wait about one minute. Then it'll start right up. What the hell? It's not the starter because it's been doing this for several years now and I've replaced the starter in that time. Any ideas?
You might need to resolder your main relay. It sits up under the dash, and 18 years of heat soaking under there works the connections loose. Or you can buy a new one. But resoldering it is free! There is a DIY in the DIY section of this site.
Ninja edit: I type too slow.1992 Prelude S w/swapped H22A
does it crank or do anything when you start it?
if it does crank it can be the main relay.
but if it doesnt crank then no way its ur main relay.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
well listen for the signs for the main relay...there is a tutorial on this website....dont just do it...test itWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
I was just having a similar problem, it would start fine when it was cold, but after it warmed up it wouldn't start back up. I pulled the main relay, soldered it back up, and its been a week now with no problems.
For whats its worth, I'm a total noob at soldering, and got it done with about 10-15 minutes of education from google, so if you've never done it before, its not really that difficult.
your terminology is incorrect...cranking is turning over.Originally posted by CB7 FanaticIt cranks, but doesn't turn over. I'm going with the main relay idea. Brand new optima battery, ground and power cables, and fairly new starter lead me to believe its none of those. Thanks for your help fellas.
Retro!
Hater
