Is there a chemical or anything you use to remove that sealer stuff that is used over the spot welds on the frame? I need to take out the 5 speed mount bracket, but I dont know how i would remove that crap. Is there an easier way other than just scraping the most you can?
How to remove seam sealer
----------------My 92 Honda Accord LX---------------------- My 97 Nissan 240sx LE----
NE GUYS, Buy the last of my accord partsTags: None
yea, thats what im talking about, but for some reason, just 2 spot welds dosent sound right to hold on the mount bracket. But there is still that silicone crap (which i beleive is called seam sealer), that covers all the edges where 2 peices of metal meet all over the engine bay.
not done a cb-7 but my jeep cj, i srcaped as much as i could with razor and screwdriver and then used a steel brush on my 90 degree grinder worked pretty good,good luckOriginally posted by JohnD1079yea, thats what im talking about, but for some reason, just 2 spot welds dosent sound right to hold on the mount bracket. But there is still that silicone crap (which i beleive is called seam sealer), that covers all the edges where 2 peices of metal meet all over the engine bay."Cracker's crumble Honkies rumble"
Wire wheel bit for a drill works A1. A better one is the black sponge looking body panel rust remover bit. That's what I used on a lot of my seams along with a 1/2 wide wood chisel. The only way to get into the tight spots where a wire wheel or other bits can't go is to scrape with a trusty flathead screw driver. Or a wood chisel, as I mentioned, works better than a screw driver. That is as long as you don't care about the blade maybe getting bent or chipped.Last edited by GhostAccord; 05-28-2008, 01:02 PM.
