SRS Delete
    SRS Delete
    Where would I go to get my srs light switched off. I bought a new steering wheel and now the light wont go away.
    You could just take the bulb out...
      true i might do that while im replacing my interior this weekend
        Be aware that it's technically illegal to disable the SRS system... though I'm about to do it myself.
          wow.. my 90 ex dont even have SRS. why is that? ive been seeing a lot with them but mine dont have it at all.
            cuz you dont' have airbags duh
            Ride: 2002 Lexus IS300
              About the cluster
              When you take apart the gauge cluster to "fix" your SRS or ABS problem, first take off the fist large circuit board and the light circuit will be behind it.
              Just beware of re-installation of the big board when putting the 6 short screws back in for the temp/ fuel gauge segment. If you overtighten them, it will ruin the spindles and those gauges won't work.
              I made the mistake of doing that, I'm gonna have to dissect another cluster.
              RoaR MRT
                Thanks for the help...sounds like I have alot of work to do this weekend....srs problem, idle problem getting fixed, timing belt, water pump, all interior replaced, and just ordering new carpet and floormats from honda, and hopefully going to try and order my RSR exhaust.
