My dome light works fine, but when I switch it to the middle, so it turns on when one of my four doors are opened, it doesn't turn on. Like I said, the bulb is fine, it turns on when I turn it to on.
I checked out the dome light housing, and to my non professional knowledge, it looks fine. I cleaned the contacts and it still doesn't turn on. My dash light for door ajar works, the little red doors open when I open those corresponding doors.
Also, whenever I open my door after I shut off the engine and take out the key (in that order), the car stills beeps as if the key is still in the ignition. Maybe they have something to do with each other?
I think all four door sensor wires meet up at some point, then from there go to the dome light. So I'm in search of that rendezvous point. maybe it's a bad wire or connection from there?
