After a hard drive when the ignition is shut off, don't the fans come on to cool the engine? A heat soak cycle to cool the engine down???
My fans did come on after I turned the car off, but recently it no longer does. In fact my fans don't seem to come on at all.
Therefore I think this has something to do with another major issue which is sometimes after a hard and hot drive, after I shut the car down for a minute to go to a store and come back, the car doesn't want to start. The dash lights come on, I get no fuel pump noise or main relay click and after the key is turned, nothing. No started crank or anything. I had to open the hood and let it cool down for like half an hour, then it will start.
I just replaced the main relay a couple of months ago so it shouldn't be that. This problem happened a few weeks after I replaced it so a brand new MR from the dealer can't for bad that fast $90!!
Anyways I think my fans not working lead to the engine remaining hot after a drive, the metal soaks up the heat and it seems like a fuel issue, maybe the fuel injection module gets overheated or something.
I really want to solve this issue so I don;t get stranded somewhere and today I got home from work and wanted to go to the gym but the bitch of a car did it just now so I have to skip my grappling class because of it.
so I want to see if I can get the fans working if it will solve the issue. is there a way to jump a circuit and see if my coolant temp sensor is bad or something.
Please help me out!
Please help me out!
