Anyone can give me some pointers on ground kit
    Hi!
    Just noticed recently alot of my wires are actually opened up and all over the place... especially the fat cable that connects the negative terminal on the battery near to the engine block.... Just wanted to know if any1 here has some pictures to help me ground a few other parts such as the intake mani, dizzy cap?, alternator, and valve cover, so i can use as an idea..???
    And how do i go about connecting all these wires to the negative terminal? i know it wont all fit... so yeh...
    Thankss In advance
    Pretty much go through the engine compartment and replace any you need to. There are hundreds of pics of everyone's engine compartment. You just gotta look around until you find what you're looking for. If it's broke, replace it, if it's peeling, replace it, if you can go up a size, go up a size. Good luck.
      Just build it yourself out of cheap cable from www.monoprice.com and ring terminals from your local hardware store. you will save lots of time if you use drop in solder pellets into the ring terminals, and then heat them up with a butane torch. If you really care, put some heatshrink over the cable and slip it down over the ring terminal once it's coole.
      1994 Geo Metro
        does ground wires give you more horses or what???
        91-accord
        watch quick clip: 10-80 mph
