please help with my headlight/corner problem
    so i decided to take the front bumper off my car to fix some things and one of the problems is the corner lamp does not fit how it should
    i could use help from someone that knows how i can fix this
    also i am trying to find a way to lift the bumper about 1 1/2" so the fitment of the bumper and headlights is how it should look stock ,
    any help would be appreciated
      You just have to adjust it carefully. Lift the bumper and tighten as you go. I have the same issue. It's just a pain in the ass. Easier with 2 people. Nothing is broken, just needs an adjustment.
        Your corner lamp looks lke you didn't bolt the arm into place, and the bumper should be an easy fix, like Deev said. There are two threaded studs that come out behind the headlights, under the hood. They will fit through brackets, and then you spin a nut on each one and lift and tighten until it looks right.
          finished result,
          but i still have a slight problem with the driver side corner light, the arm is bolted in place, everything is where it should be, but still fitment is off
