Car Died driven and will not start PLEASE HELP!!!!
    I was driven on the high way the other day and the car died and would not start
    coil not giving any spark so i changed it and it still didn't start PLEASE HELP!
    its a 92 lx with 117,xxx miles
    A.K.A BLACKCB7 ON FLACCORDS.COM
    - Ignition
    - Rotor
      well I changed the ignition tommorrow I'll check the cap and rotor thanks but I dont think spark is coming out of the ignition coil thought
        car will not start and no spark.
        if distributor cap and wires are OK.
        THEN check ignition coil and igniter.
          I changed the ignition coil, what is the igniter or where is it located
            ignitor units are inside distributor. Might just gone bad.
              ^^What he said. The ignition control module is in the distributor, so replacing the distributor might not be such a bad idea.
              I AM VTEC, HEAR ME ROAR!!
                Unless the bearings in the distributor have gone bad, there is no reason to replace it. If the new coil is already installed, and there is still no spark, then it's a safe bet that the ignitor is the failure.
                  damn Honda! haha
                  get a new distributor
                  yo tsx, here i come
                    wait didn't 92's have external igniters?
                      yes they did and i don't remember too much about them
                      take a pic of your engine pay for us and ill tell u exactly whats up
                      dont randomly change out stuff and if u do return it and say u never installed it but took it to the mechanic
                        No they didn't have an external ignitor.
                          If none of the above mentioned fixed your problem here....Main Relay might be your next best bet.
                          *Needs*
                          -New shocks
                          -Struts
                          -Drop
                          -Cleaning
                          -New Tires/Wheels
                          -New Window Tint
                          -Alot more lovin'
                            where's the main relay located?
                            What's next?
                              Its under the driver side dash. If you look up into the dash you will see your steering colum and then a silve box with a green sticker on it. Thats the cruise control modual. Take that out and it is right above that. One plug one bolt. Look for the main relay fix it diy.
                              -1991 Honda Accord LX H22a-
