Is There A Way To Check If The Main Relay Is Good Or Bad Or Is It Expensive Can I Find It At My Local Auto Parts..
Car Died driven and will not start PLEASE HELP!!!!
it could be either the main relay, if youre not getting fuel, or it could be the ignitor unit.
when you turn your key to the ACC position, you should hear a click. That means the fuel pump is working and the main relay is doing its job. The ignitor will fail when your tach on the dash kinda "jumps" when waiting at a light or something, and then you car could just shut off if thats the problem.
Also, its pretty rare, but check your ignition coil. If your 92-93, its going to be outside the distributor w/ a single wire going to it. If you're 9091, then its an internal coil and they usually fail since they're placed inside a very hot part of the car, more hot than outside the distributor.
no it controls the fuel pump.Originally posted by wis-accord View Postmain relay has something to do with spark?
Originally posted by customchordIts like 80 new or you can fix it with a solder iron. In the search field type Main Relay DIY and it will have everything you need to know.
http://www.cb7tuner.com/vbb/showthre...ght=main+relay
