As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
Changing Oil Seals Question
    I need your help guys. I am currently changing my timing belt, water pump and as what everybody recomends, the front engine oil seals.(cam, balancer shaft and crankshaft seals) This is my first time doing it. I think I will be able to manage the timing belt, balancer belt and waterpump. My problem is the front engine seal. Do I need a special tool to instal the new seals on or I can just use my hands to put/press the new ones in? I don't want to pull out the old ones and then not being able to put new ones in because I dont have the special tool. I've tried searching but I can't find any related thread about it. I have the front engine disassembled already and this is the only step that keeping me from putting it back together. I would just leave them alone but, I can see them starting to sweat a litlte oil around them. I realy need your help on this so I can put my car back together again.
    Thank you very much
    the hradest part would be taking the old one out without nicking the crank. i put the new one back in with a hammer and socket to set it flush with the housing.
      i'm currently changing my own timing belt/water pump as well. I'd also like to get some information on replacing the seals.
      I've been looking on hondaautomotiveparts.com (majestic) but I can't seem to find the right parts. maybe Honda identifies them with a different name but can anyone provide a picture or part number for these seals?
        I think there is a special tool but when then honda tech did mine I think he also use a socket to push it in.
