Bogging/Lack of power.
    I have found this site to be very helpful. http://techauto.awardspace.com/transmission.html
    Going to pull a part to pull a TCU.
    Facebook.
    Xbox Live: Call Of Duty4: Unt0uchable15 --I'm a beast!
    Member Ride
      Originally posted by jdmtypecb7 View Post
      c92blx7 said replace tcu, which i believe is 'transmission control unit'. anyone wanna confirm this?
      yes.tcu means transmission control unit.and how long is it bogging?my car was doing this and i played with the idle adjustment screw and it purrs liek a kitten.....also.i cleaned out my iac valve and got new plugs/wires...try that it ran alot smoother afterwards
      spoonsportsaddict
        im glad this thread came along cause im havin the same problem!! doesnt do it often but when it does its horrible. didn think to try shifting from 1!!
          Don't make a habit of switching from 1. It makes your transmission last longer if you don't shift it like a manual. But yea it does suck. I'm about to leave now.
          Facebook.
          Member Ride
            It bogs when I first take off, and if I don't keep on the gas on the highway it goes down fast, then I have to hit it extra harder to get to the speed I want. It just doesn't want to go.
            Facebook.
            Member Ride
              clean your iac valve.wires/plugs/filter.do a tune up.
              spoonsportsaddict
                Just cleaned my IACV, it was pretty clean. But then I checked my wires. One of them has oil down in there, on the sparkplug i'm guessing. So I guess I need new wires, and plugs. Causing it to misfire? Do I have a connection there, with it hesitating and having acceleration issues? I haven't changed the fuel filter since I have had the car.
                **Actually, all of my sparkplugs & Wires have oil on them. Valve Cover Gasket??
                Facebook.
                Member Ride
                  K guys, bought a Valve Gasket, some NGK VPower, and a fuel filter. Let you know how it goes.
                  Facebook.
                  Member Ride
                    good luck.you'll feel a difference
                    spoonsportsaddict
                      Yea. I shouldn't have bought a FelPro Gasket. Those things suck! But anyways from me having lack of sleep, I accidentaly broke the head stud. Thank God, I have another head. I'm taking a break it's quite hot out there. Do you think I'm fixing the right problem that is causing the hesititation?
                      Facebook.
                      Member Ride
                        my car hesitated horribly..like i would stomp it and it'd take almost 3 seconds to kick.i clean'd the iac,got new plugs and wires and its purring like a kitten
                        spoonsportsaddict
                          Ok Guys, I'm depresed. I got the plugwires, plugs, fuel filter installed. Cleaned IACV. Same old crap.
                          -When I go in Reverse it has all the power in the world.
                          -When I put it in 1st and 2nd, it's great.
                          -When I put it in D3 and D4, Crap!
                          -When I manually shift 1,2,3,4 it's fabolous(as I'm driving.)
                          Do you guys think I'm dealing with a bad transmission?
                          Here's what it is doing once again.
                          I start from a stop, hit the gas. Atleast a 2 second delay while revving. Then it goes.
                          So fellows, My dad thinks it's a TCU or a Solenoid, what do you guys think?
                          Last edited by cleanwithit0607; 08-15-2008, 08:12 PM. Reason: I'm a compulsive editor.
                          Facebook.
                          Member Ride
                            i think it your timeing is a bit off
                              Timing is good.
                              Facebook.
                              Member Ride
                                Timing is good.
                                tcu.
                                spoonsportsaddict
