problems with the hydraulic direction
    Hello
    I need your help, I have problems with the hydraulic direction of my CB7. every time I give a return can be heard around the throne, besides the fluid is pulled, is when the steering wheel becomes too hard and it's hard maneuver
    What?
    wat?
      Originally posted by TOLUCO View Post
      Hello
      Huh?
        So when the steering wheel is returning to straight you can hear a noise?
        wat?
          I thought it is better to remove the PS, this would help me to reduce a little weight, who think.
            is there enough fluid in the Power Steering Reservior?
            do you hear a moaning or whining noise while turning?
              yes
                yes
                  If it takes one week in wasted fluid
                    try to find where it is leaking from. is it leaking from the pump? the pump might be bad. or there is a big leak somewhere making it run out too fast.
                      Welcome to the site, where are you from? your posts read like they've been translated four times.
                        ok thanks
