Anyone know where i could get just the syncros for my f22a1 tranny?
Need Syncros...
Originally posted by js593 View PostHonda, Rockauto.com, you can try MajesticHonda (online). Ebay MAY have them, but i doubt it. Local tranny shops (that specialize in transmissions) will usually be able to get all the parts you need.
His answer was better.... not to post whore or anything... just very talkative tonight... Sry
Rev matching is too hard to do, even with burned out syncro's. My friend did it for 4 months on his civic, he had to replace his whole tranny after a syncro blew, and put a nice 2 inch hole in the tranny for some reason... in my eyes it was pretty funny.. but his wallet was hurtin.Originally posted by Flatline View Post
His answer was better.... not to post whore or anything... just very talkative tonight... Sry90 Accord EX F22a1 Auto R.I.P.
2011 Mazda 3 Hatch 2.5L GS sport HELLO!
Rev matching is easier on the gearbox than not rev matching, but getting it wrong a lot will eventually do damage, if getting it wrong means crunched shifts. It's not that hard to do, but it does take practice, and some people never really get the knack...
With some cars (some Hondas at least) some actions of the IACV can make rev matching a lot harder (to get just so), better to blank it off (i.e. blank off air flow through the IACV, don't disconnect the electrical connector, the computer doesn't like it).Regards from Oz,
John.
have you tried the new honda mtf or the penzoil syncromesh? My street car was grinding until I put in the syncromesh fluid.1990 accord Honda-Challenge, H22 powered
newer race video,older race videos
1991 accord parked, parts and back up shell
1993 accord acquired 6-11-16
i actually did some research not too long ago and i found rev matching pretty easy myself...
then i also found a tutorial on shift without the clutch as well and that too was pretty easy. If you pay attention to your tach a lot then it is easier because you know where you need to be...
and with clutchless shifting... it basically said to let off the gas and as soon as you fell the car start to drag just shift real fast and it works... no grinds or anything. Rather suprising.
Knowing where to get the synchros is the easy part. Installing them isn't so easy. It's basically rebuilding the entire transmission.
Check out www.gear-speed.com.
Then I would suggest it's possible that you aren't doing it correctly...Originally posted by accord...black View PostCan't rev match cuz it wont "slide" into gear. I have to slow the car down to 25mphs for 4th and 15 for 3rd and i have to be stoped to put it into 1st and 2nd.Regards from Oz,
John.
