Hi there! I just discovered this forum and I've been researching all day trying to understand my problem.
I have '91 Honda Accord EX/4 door. It has power windows too.
About a month or two ago, my driver side door became stuck and impossible to open/unlock. Apparently this is a common problem with early Accords because there's a lot of discussion about the issue. What I want to determine is.... what exactly is my problem?
I've seen the drilling tutorial to unlatch the door but there must be another way! I'm not even confident that it's my lock actuator yet - what if the rods are just jammed in some way? I've read about other people avoiding all the drilling work by taking apart the door, lubricating the lock rod parts with WD-40 and managing to wiggle and free whatever was jamming the locking mechanism... and presto! it was fixed. That would be ideal.
The manual inside lock on the top of the door has been unable to go down completely ever since the problem started. When I wiggle it around, it has a little leeway but it feels mechanically jammed and it stays in an almost unlocked position. HOWEVER, when I pull the door rods/handles to the open position, the manual lock can almost move normally... almost... but it's stuck.
This is the first car that I've ever worked on and this problem seems pretty bitchin but I'm determined to figure it out anyway. So my questions are....
So I'm going to assume that my answer is going to require taking a look inside my door and opening it all up for better access. Well, I'm already a step ahead and I've just run into a frustrating problem in getting my door panel completely off. I removed all the screws, all the clips, all the plugs.... EXCEPT! the biggest connector that's attached to the Power Window assembly. My Hayne's manual says to just pry to the whole assembly out of the door panel but being new to mechanics, instructions like that are really vague - especially when I feel like I'm going to break something.
So here's some pictures to exemplify what I'm talking about...
I assume that I'm gonna have to completely remove my door panel. correct me if I'm wrong. but if I do, I'm gonna have to figure out how to disconnect this bitch of a connection.... I've tried everything. brute force. pressing on all the spots that SEEM like theyre meant for removing it... I hope I'm an idiot and theres a really simple reason for why I cant get this out.
my manual door switch...
okay... now here are some pictures of my actuator unit and the rods...
maybe somebody who's done this before can see something funky in these pictures and tell me what's up.
either way! thanks for reading.
- How can I determine what the problem really is inside my door?
- How can I tell if it's the lock actuator/latch/or the rods getting stuck somewhere?
- Do I need to completely remove my door panel? And if so - how can I loosen the power window electrical connector?
