I bought one from the dealer and when I took the old one out to match, I noticed that the new one did not have a Spring Load thingy in the middle wich looks important. Now I am left to either put it all back the way it was for now or leave it like that till next week. Any help would be appreciated...Pics even better. I will post pics of the difference soon..
Trouble Changing D/S Window Regulator.
Well. Did some research, and it seems that the FREECKIN Dealer did not sell that SPRING thing along with the Regulator...
I just don't get the fact that if you buy a part that NEEDS a nother part.. WHy not SELL both parts TOGETHER....
Example....I bought the Valve Cover Gasket... Forgot about the 4 O Ring Gaskets for the Spark Plug holes. Guess what, I had to go back and order those too. Why not just put them in a simple One Item Number so that you pay for both at the same time and for them to come together..
WTF!!!!!!!REDLINE
Babies are bottle fed, real men are BLOWN!
Went to the Honda Dealer....
This morning I went to the Dealer. Told the guy everything I thought on the hole spring issue. The guy calls the manager over. The manager was the guy who sold me the Regulator in the first place. He looks on the computer a bit and then takes the old regulator and the new one to his Main Tech.
The Spring part is a discontinued item. No longer used in the Regulator. They advised me to put in all back like that and it should be fine.
We will see what happens....
This is info on this common issue on the driver side window of our CB7z. Thanks.
Here are some pics of what I was talking about.
The Spring is in the center. My thought is that is some how helps the motor.
I will fix the size of my Sig Pic today.Last edited by REDLINE; 08-29-2008, 11:58 AM.REDLINE
Out Come!!
Not what I expected....
After all the trouble. I changed the Regulator. And still the window does the same thing when fully closed. So, my guess is that it is not the Regulator that was the problem. My thought now is going more for the Window Frame Rubber or the Motor is weak.
It made me pretty upset. I am so glad that my DB1 Integra does not have window frames...REDLINE
