Anyone else ever install a P12 with a f22 and notice the idle is a little ruff? I just noticed it today. It idles around 500 RPM.
Idle loopy after installing P12
Ok now I'm starting to have some worse problems. I just took the car for a ride and after about 5 minutes of driving, the car was sputtering around 2000 rpm. I would let off the gas when it did this and the rpm would drop really low. I'm talking like 100-200 rpm. Then i would floor it and it would sputter for a second, then just take off like normal. What could be the cause of this? It ran fine until today and I just installed the p12.
oil in spark plugs?
I will have to check tomorrow. I hope notOriginally posted by Losiracer2 View Postoil in spark plugs?
One spark plug just had a slight bit of oil on the threads but I think that was from when my valve cover gasket was leaking but I fixed that. I used the car all day today and it ran fine the whole day. There was a big storm yesterday and I'm thinking maybe something just got wet and was causing the car to act weird.
Ok I think I know what is wrong with my car. The main relay must have went again today because before it was not starting and I took the bolt off the fuel rail and had someone crank it over and no fuel shot out. I then taped on the relay and it started right up. these relays suck! This is the 3rd one I went through in a month. Im going to buy a new one, and install a fan on it.
