By the steering coloum. What does it do cause i think that why my car wont start. Whenever i turn the key it just clicks and wont start. I have to push the car to start it.
Silver box under the dash?
Hmmm. there is a silver box by the column for the cruise control...
I think it's something else. i would check the starter. if it clicks by won't turn over it could be that.
Or i had to put a bold into a part of my clutch pedal assembly to push a pin in as well because it wouldn't start. but i don't know of any other silver boxes under there.
Pics????
It's above the silver box, actually...
And it doesn't matter what transmission, engine, etc... It's a relay that controls the fuel pump. Simple as that.
Unbolting it is a pain in the ass. I didn't bother. My old one (which I think is still good... it wasn't my problem) is still bolted in there, and the new one is just tucked up there.
If you are push starting it, it's a stick. Look in your floorboard. You will probably find a small piece of rubber the same color as your interior. This came out of your clutch pedal. When this cracks and falls out, the clutch switch pin goes through the pedal, and does not engage. The wonderful thing about this is that the clutch pedal assembly has to be removed to replace it. You can just by pass the switch, but not safe. I replaced mine with a plastic push in clip like a door pane clip. Two days later the one on the brake switch broke, and my car was sittng half the day with the brake lights on. Door panel clip and done. If you can put the car in neutral and start it with a remote starter button, check the clutch switch.Originally posted by lilshaun1983 View PostBy the steering coloum. What does it do cause i think that why my car wont start. Whenever i turn the key it just clicks and wont start. I have to push the car to start it.My inferiority complex isn't as good as yours.
